4l65e wiring help? 05 tahoe 4x4
Old 12-31-2015, 06:01 PM
tag5071's Avatar
Default 4l65e wiring help? 05 tahoe 4x4
Hopefully somebody can help with a quick question. I just replaced the trans in my 05 tahoe. I ended up with one 2 pin connector left unplugged. For the life of me I can't find where it goes.
The wires are green and purple and comes from the same harness as the large grey round connector that plugs into the trans.
Also i have all three 2 pin connectors plugged into the nv246 trans.
This wire seems to have disabled by speedometer and it won't shift higher then first or second gear.
Any ideas? thanks in advice for your help
Old 12-31-2015, 06:19 PM
Moderator
mrvedit's Avatar
Its for the VSS (Vehicle Speed Sensor) which is in the tailshaft of the trans.
Old 12-31-2015, 06:24 PM
tag5071's Avatar
thanks for the reply. I thought it was for the vss too, but I have a concoctor plugged into it. that would leave me with another connector.
All 3 2 pin connectors seem to be in the right spot. The harness isn't over stretched or have extra wiring length anywhere.
Old 12-31-2015, 06:46 PM
tag5071's Avatar
just to double check. I just tried to se if the unplugged connector would reach to the vss sensor on the tail shaft. It definitely a few inches too short.
Old 01-03-2016, 09:19 AM
tag5071's Avatar
in case anyone else misses this plug when reinstalling their trans. I dropped the front driveshaft back out. There is a bracket above where the trans and t-case meet. On it is the other end of the harness.
Quick Reply: 4l65e wiring help? 05 tahoe 4x4
