Smart Shift PADDLE SHIFTER any reviews out there?
Ive googled, ive searched here and ive looked on summit and jegs still cant find a single review on this product.
http://www.performanceautomatic.com/...E_SHIFTER.html
Performance Automatic Smart Shift Paddle Shifters PA99110
Performance Automatic has another addition to its electronic Street Smart Systems line. The Smart Shift Paddle Shifter is designed to provide paddle shifting capability to your Muscle Car or Street Rod with the look and feel of an OEM system. Easily installed behind any aftermarket 5, 6, or 9 bolt steering wheel, the Smart Shift Paddle Shifter does not require any external wiring or messy splicing into your vehicle’s wiring system. The paddle unit is powered by simply attaching to the horn button wire, eliminating any external wiring on the column. The Smart Shift Paddle Shifter communicates with the transmission control unit via a wireless receiver module. The receiver module plugs into your Smart Shift Transmission Controller unit harness with one simple, pre-installed plug. The Smart Shift Paddle Shifter also comes with a display that allows the driver to view many items including, vehicle speed, engine RPM, TPS, coolant temp, TCC lockup, transmission temp and gear position, plus many others. The Smart Shift Paddle Shifter comes complete with; Paddle Shifter, receiver module, wiring harness and hardware. What a great way to upgrade your Smart Shift Controller or your electronic Street Smart Systems Package.
Wireless connection is very interesting, does anyone have real world feed back using this with a 6L80E?
Moderator
I suspect it only works with their own Trans controller which only supports the 4L60E and 4L80E.
Some cars with 6L80E were available with factory paddle shifters; however wiring the OEM parts to a non-OEM steering wheel would probably be very complex.
