4L80 swap guys
4L80 swap guys
4L80 swap , what did you do for a Trans mount in your ride? Shim or no shim?
I have a crazy harsh vibration after the 80 swap that wasn't there with the stock 4L60 or the TH400 w/ brake. 98 Z28 in sig.
Only after the the 80 swap has this vibration popped up, same torque arm as the TH400 and the same Moser 12 bolt as all the transmissions.
Driveshaft was made by a local shop that's very good at what they do.
Any info you can share will be appreciated , I can't take this beast on the highway it's so harsh.
Thank you in advance
You think the angle changes from the TH400 it had to be 4L80-E? I can get that checked . That's somewhere to start , thank you .
Make sure you have enough yoke in the trans
A lot of time on 80E swaps, the trans ends up pointing downward due to hitting the floor, and the angle is off to the rear
Meas the trans angle, and the rear angle-picture a straight line from the trans, and a straight line from the rear-they should be close to parallel with each other, maybe the rear down a couple degrees
Thanks
