deep sump pans worth it?
Typically the rule of thumb with transmissions are, the cooler you keep them the longer they will last. Deeper pans that add 1.5 or 2 qts of trans fluid really isnt a bad thing and alot of people do it. If you plan to offraod or rock climb or crazy stuff where clearance would be an issue than I wouldnt bother with it. Some people look at it in a sense of "with a factory pan my trans lasted 200k or whatever" and in all reality I dont think a deeper pan will add a ton more life to it if thats what your asking. Adding the cooler is definitely a plus though.
Also if you go deeper on the pan make sure to get a longer pickup tube and filter as well and make sure its fully supported. Ive been out of the transmission hame for a while but i remember people changing pans and later ruining there trans because the pickup tube didnt stay on and obviously if its too short it will starve
