What kinnd of custom converter is needed for long crank lq4 and 4l60e?
I recently picked up an lq4 short block that needs to be rebuilt that has the longer 99-00 crank, and I also have a spare crank that is the shorter 01+ version. If go with the long crank since that is the original piece, what kind of converter do I need to get my 4l60e to work?
LS1Tech Sponsor
feel free to call the shop or shoot me a message if you have any questions!
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
LS1Tech Sponsor
Then you'll need the SRLS (300mm) style converter for the 99 and up style 4L60E converter with a cut down pilot to fit the crank. If you would like to. fill out one of build sheets at the link below and we can get this converter built for you! We can also build the converter to fit your flex plate as well.
ftiperformance.com/build-sheet
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
LS1Tech Sponsor
Since you have the long crank you have to use the flat flex plate for correct spacing.
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
LS1Tech Sponsor
If you end up going with the short crank a normal LS style 4L60 converter will be perfect! no need for a cut down pilot
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
