4L60E Checkballs
Old 06-20-2004, 09:53 AM
mrt73tex's Avatar
Default 4L60E Checkballs
Can anyone tell me where to find info for the checkball locations in the 4L60E valve body? Lost reverse gear after rebuild kit was installed.
Thanks.
mrt73tex
Old 06-20-2004, 10:54 AM
Jeff406cid's Avatar
The only checkball pertaining to reverse is in the case, and won't cause a no reverse situation. Most likely the culprit is the solid teflon rings on the pump which can get torn very easily especially if the rings weren't "sized" long enough. You did use the tool, didn't you ???? :o
I'll email you with the correct checkball location anyway.
Old 06-20-2004, 11:22 AM
Jeff406cid's Avatar
Well so much for the Email, but let's try this:
Attached Thumbnails 4L60E Checkballs-picture-4a.jpg   4L60E Checkballs-picture-9a.jpg
Old 06-20-2004, 11:47 AM
2xLS1's Avatar
Where can I get that manual?
Old 06-20-2004, 05:32 PM
mrt73tex's Avatar
...no tool used. Guess I did a bad thing...
Is there a way to tell that the rings are damaged by looking at them?
mrt73tex
Old 06-22-2004, 11:02 AM
Jeff406cid's Avatar
Yes, if you pull the pump and find the rings are cut, or have a chunk missing out of them, then guess what?? :O
Old 06-22-2004, 11:11 AM
Jeff406cid's Avatar
You can get it from your local trans parts supplier, or from a few places online.
These are my guys:
http://www.cargotransmission.com
A great bunch of guys, and good pricing too. I do recommend that you order the 4L60E manual, and the update book. They both contain unbelieveably valueable information.
Quick Reply: 4L60E Checkballs
