? On a prndl switch
? On a prndl switch
Hello I'm getting a psi wire harness har1014 and I talked to psi and I asked if the wire harness had the wires for the prndl switch and they said no and I don't need the switch I'm using a 4l65e 04 ish transmission. And it's dbw
Do I need the prndl switch for the transmission to work right?
I have a b&m shifter that has a neutral safety switch on it .
I have a compushift 1 and when you put the trans in gear it tells the controller what gear its in.
I'm assuming your Talking about the black box on the driver side .
You do need it if you want to run the neutral safety and rev lights off of it tho
My b&m shifter has the light switch and safety switch.
So I know in turning the motor it has charts for in gear and in park .
So what has every one done on a stand alone harness for the tune if you are not using that switch ? Since it sounds like they delete it for the stand alone
Thank you Kelly
Moderator
As mentioned, the "black box" only implements the Park/Neutral safety switch and controls the Reverse lights. Nothing else - IT DOES NOT tell the PCM what gear the shifter is in. The 4L60E internally determines if the shifter is in [D1], [D2], [D3] or [OD] and tells the PCM through the trans wiring harness.
BTW - I also have the B&M shifter and no "black box".
