Prepping for Stall Converter
Have a 99 Z28 with 120k miles. Recently purchased so I dont know the true history other than it has a shift kit installed.
This is what Im considering...
Rebuild kit
http://www.700r4l60e.com/store/produ...&cat=55&page=1
Either a 3600 or 3800 Stall
Trans Cooler
Tune
Ive read about larger pans too. Anything else to consider? Thank you - this will be my first rebuilt tranny and stall converter
focus/goal: street car/daily driver.
- Cam/Head swap later
Rebuild kit
Trans Cooler
Tune
Good stall speed choice. Get a minimum of a B&M 70264 trans cooler. I'd also highly recommend a gauge. I went with Aeroforce OBDII gauge for ease of install and for how many other things it can monitor. Get this... my trans temps ran hotter with stock converter before installing the trans cooler than it does now after trans cooler and SS3600. I installed my 70264 dope style separate from stock cooler(lots of debate about this that depends on your location and usage).
3600-3800 stall will make a huge difference in the performance of the car. If everything else seems to be in good working order the only other things I recommend is a tune, and transmission cooler.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
LS1Tech Sponsor
The 36-3800 is a great choice! One of our guys here has a 3600 in his Silverado and he boils 35s like they're free, its awesome! lol
With a 36-3800 stall converter a cooler and a tune will be a must! the pan is not but it wont hurt either budget permitting(you can always add it later on). I think a good freshen up/rebuild, converter, cooler, and a tune you will be very satisfied with the results.
I see heads/cam later on, is the motor stock now? Also are you doing heavy towing?
-Dalton
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
-Dalton
-Dalton
I need to find a dependable transmission shop around Orlando. If you could PM me a quote on all of this work - I'll consider FTI. Thank You
