M6 to 4L80E wiring question
I have a 2000 SS Camaro. It used to have a 6 speed but now I'm swapping in a 4L80E.
I have all of the electrical plugs for the trans. My question is regarding the 11 wire circular plug on the driver side of the trans. I need to know which Pins these wires plug into which computer.
Does anyone have a wiring diagram i can use to pin the 4L80E trans plugs into my 2000 camaro 6 speed ECU's?
Thanks Glenn
Thanks Glenn
Moderator
This thread has the requested info and diagram, although the diagram is a bit hard to read.
http://www.pacificp.com/forum/viewto...5c651b71d84f56
While it references a truck PCM, I checked that the PCM's C1 and C2 pin numbers match up with what I have.
BTW I found this by Googleing "4l80e wiring diagram" and looking at the Images.
Thank you mrvedit. I saw these on google before hand but I was not aware the computer in my camaro would have the same pin layout but it sounds like that is what you are saying.
