4l80e fitting problem
I have a 97 hydromatic 4l80e. Has front and rear for cooling lines. The problem I'm having is the rear fitting (long one) won't screw in because it's hitting something in the Trans. Need help. Thanks
Wrong Center Support at the very least, This is Bad.....Real Bad!! The trans will need to be torn down to see what all is wrong for your "Center Lube" Case by someone that knows what the hell their doing!!! It may end up cheaper to buy another core to build.
