shift parameters for 4L60E
Old 10-16-2016, 03:21 PM
davidb5303's Avatar
Default shift parameters for 4L60E
I have a 5.3 with a 4L60E trans and the motor runs super but it doesnt have the "pep" it should when your going down the road and get in the gas. I think its in the trans tuning cause it doesnt really downshift even at 100% throttle. So just curious if there are certain percentage of throttle there telling trans to downshift or shift at? Hoping someone can fill me in so i can tall intelligently to the tuning guy. Or are there any good places in Northern Illinois that do this? Thanks
Old 10-16-2016, 03:45 PM
Moderator
mrvedit's Avatar
Yes, depending upon speed and throttle position the stock tune will obviously downshift.
For example, in the stock 2002 Camaro SS tune:
At 50% throttle it will downshift 3=>2 below 33 mph.
At 100% throttle it will downshift 3=>2 below 86 mph.
If your trans is not downshifting, you should start by using a scanner to confirm that the PCM is ready the throttle position correctly via the TPS.
Old 10-16-2016, 04:06 PM
davidb5303's Avatar
OK thanks...I will have the engine tune guy check that...its a 5.3 and 4L60E that i put in a 76 Trans Am. I was just hoping for info so I could ask him smart questions or tell him "these are the parameters i want it set to" kind of thing.
Old 10-16-2016, 05:56 PM
davidb5303's Avatar
is there an inexpensive scan tool that i can use to reap the TPS?
Old 10-16-2016, 09:07 PM
Moderator
mrvedit's Avatar
I would expect that the scan tools you can rent for free from auto stores will display the TPS %. While I use HP Tuners, my cheap Harbor Freight scanner also displays TPS %.
Old 10-17-2016, 10:05 AM
davidb5303's Avatar
I am sure this is a loaded question but... is there a generic set of parameters that I can say"this is what I want"? For my trans to do in my 5.3 swap in my 76 TA?
Old 10-17-2016, 10:07 AM
davidb5303's Avatar
And which "inexpensive" harbor freight diagnostic tool do you use!
Quick Reply: shift parameters for 4L60E
