driveshaft length questions
Old 11-27-2016, 02:51 PM
fastlt1's Avatar
Default driveshaft length questions
Planning a th400 swap in my 99 z28 this winter. Next season plan is ford 9 inch swap. Is there any way to spec a driveshaft or use the same driveshaft for both. Will be spraying and launch transbrake with 9 inch
Old 12-31-2016, 07:28 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
I know this thread is old but no one replied to your question. A 9 inch typically requires a one inch longer driveshaft to have enough engagement into the transmission. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 12-31-2016, 07:53 AM
fastlt1's Avatar
Thanks for the reply. Does the 12 bolt 10 bolt 60 and 8.8 all use same length driveshaft
Old 12-31-2016, 08:26 AM
LS1Tech Sponsor
You're welcome. The 10 and 12 bolt take the same length, not sure on the others but I believe they are a different length. Bob
__________________
Old 12-31-2016, 06:58 PM
fastlt1's Avatar
Do the pst drive shafts come with both u joints and transmission yoke
Old 12-31-2016, 08:57 PM
LS1Tech Sponsor
http://shop.brutespeed.com/Driveshafts_c1090.htm
Yes they do. Bob
__________________
Old 01-31-2017, 05:08 PM
fastlt1's Avatar
I got 48 inch that is from transmission seal to yoke. Would be x on pstds.com anyone know if that is right
Old 01-31-2017, 05:59 PM
Moderator
mrvedit's Avatar
My suggestion is to raise the car up with jackstands under the differential tubes, crawl under it with your cell phone and tape measure, and then call the driveshaft company and ask them exactly what to measure. Some measure to the front of the yoke, others to the middle.
Also the measurement depends upon whether the rear suspension is compressed. Typically they want it compressed (e.g. jack stands under the differential tubes, not under the frame) as a level-compressed state will be the shortest distance.
Old 01-31-2017, 06:04 PM
Launch's Avatar
PST makes a quality driveshaft and Bob @ BruteSpeed will hook you up easy.
Old 01-31-2017, 06:44 PM
Launch's Avatar
There is a 1" longer than typical pinion yoke available for the 9" ford centers, so it will bring your driveshaft length back to the same as it was with the stock 10-bolt.
Google ' ford 9 inch long yoke '
Quick Reply: driveshaft length questions
