What yoke for this 4l80e shaft
Hi guys I've read a lot of the yoke threads and I'm still confuse .. can anyone tell me what yoke I need for this 4l80e shaft .. I need to have the yoke welded to my stock s10 shaft.. the splines are continues to the rear and I don't see a ridge on the middle if the splines for an o ring. Thank you in advance !!
It needs a nothing special th400/4L80E 32 spline SLIP yoke. No counter bore or anything. Usually a van application.
That sleeve has an o-ring on the inside and it used with a vented yoke, one with a small hole in the end.
I'd take the sleeve off and use a non vented yoke.
A counter bored yoke will also work, but will have less spline engagement.
And obviously you want one that matches your driveshaft, doesn't make much sense to have a yoke welded on the driveshaft to match or get stuck with a crossover u-joint.
I got a little lost with the yoke that matches my driveshaft.. what type of yoke would match my drive shaft .. what exactly would I be looking for in the yoke that I would know it would match my drive shaft and transmission.. I was just going to take the yoke to the driveshaft place because I needed to get shorten and have them weld the yoke end from the 4l80e
If you're going to have a driveshaft shop do all the work you really don't need to know all this. Just tell them the length and transmission.
So I bought the yoke . But look what happens when I push it in . It slips out like it's building air pressure and I'm not able to fully inserted . I only get about 3 inches engagement. Any thoughts ?
