Th400
BOP stands for Buick, Oldsmobile, Pontiac.
You can buy a chevy case for way cheaper than trying to adapt that to an LS engine. For that reason I'm sure no one has even bothered to make one.
The only other option is to cut it off and use an aftermarket bellhousing that attaches to the pump bolts.
LS1Tech Sponsor
You can build the BOP case and it may not be a bad idea if the core is a good one and its free... just know you'll have to cut the bell housing off and put Ultra-Bell on the unit to bolt to the LS engine. expect somewhere in the $300 range for the UB
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
this is what i was thinking,at the power im trying to make i would need a ultra bell for any trans 1000-1300 hp
LS1Tech Sponsor
i agree 100%!
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
