Hughes Adapter with TH350 issues
Guys,
I know this has been beat to death. Ive searched and cant find any answers. I am swapping a sbe turbo 5.3 into my LT1 T/A. I bought the Hughes adapter to use with my dished stock 5.3 flexplate. When I matted the trans to my mock up 5.3, the hughes adapter is too long and wont let the converter slide up to the flexplate. When I removed the hughes adapter and matted the trans up, the converter has about 1/8" gap from mounting tabs to the flexplate. And when bolted to the flexplate the pilot(correct name?) just barley slides into the crank.
Converter is a Revmax that I ran in my previous Turbo 383 LT1.
Anyone have this issue? If so whats the fix?
***EDIT***
Hughes adapter seated in crankshaft. This is the gap I have trying to push flexplate onto crank.
Here is when I have flexplate bolted to crank, trans bolted to motor. The pilot is just barley in the crank.
Here is my flexplate to converter mounting tabs gap. With out hughes adapter
***EDIT***
LS1Tech Sponsor
Guys,
have you checked the bolt circle as well?
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
The picture you posted is a pilot extension these are used when a stock torque converter from a th350 or th400 are used so you can use it on an LS motor. I have one in my my car. The only part the slid into the crank was just the smallest part on the pilot extension were it cones down.
LS1Tech Sponsor
Soloman is perfectly correct!
with the pilot extension you have make sure it goes all the way into the crank and all way over the pilot on the converter, it may be hanging up on something and that is why it appears to not being going all the way in.
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
As for bolt circle, he was referring too the bolt pattern on the torque converter does it line up with the bolt holes on your fly wheel.
The reason I did this was to see if there were any issues before I mate my good 5.3 to my th350 before set them in the car.
Did you try putting the extension on the pilot of the torque converter? and bolting it up to the mock up 5.3, instead of putting it on the crank.
I attached a picture this is how your trying to bolt up the converter to the engine correct with the extension the the crank?
How much of the pilot needs to be inside the crankshaft? (as if you don't need any adapters or spacers)
Yeah you'd have to post some pics man. Rarely have i herd this being an issue.
Ok lets see. This converter was on your 383 LT1 witch I'm assuming was swapped to a th350 because the LT1 had the old style 4l60e. Was this converter made specifically to bolt up to the LT1 flywheel? or is its a stock revmaxx th350 converter.
http://www.sonnax.com/parts/1059-pilot
LS1Tech Sponsor
1/8" pilot engagement is fine
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
