im about to fix code p1870 1-2 hard shifts . I need some advice!
Old 01-29-2017, 09:35 PM
ikaros23's Avatar
Default im about to fix code p1870 1-2 hard shifts . I need some advice!
well I've seen countless and countless of threads talking about the same subject. I took the valve body out and im about to replace the tcc valve with this.
Im also be replacing solenoids A-B for 1-2 and 3-4 shifts. and both front and back gaskets from the separator plate. My question is, what else could i replace while I'm at it?
Old 01-29-2017, 10:35 PM
Moderator
mrvedit's Avatar
You might consider installing the Transgo HD2 kit while you have the valve body out.
I highly suggest the Sonnax 4L60E-LB1 boost valve.
You might consider the Sonnax Forward and Reverse abuse valve kit:
http://www.sonnax.com/parts/2462-for...buse-valve-kit
If you have made engine upgrades and visit the drag strip, I highly suggest the Sonnax HD 2-3 shift valve:
http://www.sonnax.com/parts/2464-hea...-3-shift-valve
Old 02-12-2017, 10:13 PM
ikaros23's Avatar
Thanks for your input. I was able to successfully put the valve body back in its place with the parts you mentioned and then I torqued down every bolt to factory specs. After that I took a 2 hour long trip and the car shifts flawless. Couldn't be any happier
Old 02-13-2017, 07:50 AM
Moderator
mrvedit's Avatar
That is great news.
Those parts should give you a perfectly functioning valve body.
The Fitxall valve's On/Off (instead of PWM) TCC apply should make the lockup more noticeable. Can you feel the difference?
I think the On/Off feel of the lock up clutch is actually desired by most members here.
Old 02-15-2017, 02:17 PM
ikaros23's Avatar
That is great news.
Yes i do feel the difference when it goes off . Can you explain the function of going on/off. I do feel a bit of rpm drop after reaching 50mph. Is it to save gas among other things by keeping the rpms lower?
Quick Reply: im about to fix code p1870 1-2 hard shifts . I need some advice!
