Thinking about swapping 4L60e to Th400, what additional parts will I need?
Old 06-30-2004, 12:15 PM
MeanWS6's Avatar
Default Thinking about swapping 4L60e to Th400, what additional parts will I need?
Will I need a new console, shifter, flexplate, anything else?
Old 06-30-2004, 02:26 PM
WhatCam?'s Avatar
If you do a search, there is parts list allready posted, and pics of finished installs.
should get plenty of info on the topic
Old 06-30-2004, 11:54 PM
Elite_Hot_Rod's Avatar
Well as you already know you will need an front upper M6 shifter console, shifter, dipstick tube, flexplate, tranny x member and a drive shaft.
Old 07-01-2004, 01:01 AM
Naked AV
Guest
Posts: n/a
Yeah, you'll need one of these too.
Old 07-01-2004, 02:50 PM
Dean98TA's Avatar
I checked into what it would take to get one of those to work on my car, and it requires I change the stock torque arm setup to something else, like bolting up to a crossmember closer to the rear end.
The Gearvendors unit definitely will not clear the stock torque arm mount setup, and maybe not even the aftermarket torque arms that bolt up to a chassis mount in the tranny tunnel.
It's not impossible to install, but it's not plug and play.
Old 07-03-2004, 08:47 AM
taqwache's Avatar
also you will be going backwards since you will just be adding a crap load of weight to the car. plus all the power you will be looseing pulling a TH400 and one of those. if you want OD, just get a rossler 4L60.
Old 07-03-2004, 08:48 AM
taqwache's Avatar
https://ls1tech.com/forums/showthrea...&highlight=***
this is the absolute cheapest way you can do it, if your low on cash like me.
