Next tranny question.
If its the 1-2 accumulator (in the seperate housing) use compressed air through the feed hole and blow it out (point it away from you). If its the 3-4 accumulator (in the case) you can just grab it with pliers.
Make sure you push the piston down first to force out most of the fluid, or you'll be taking a nice bath in 3 ounces of ATF when you blow it out with the air!
ratios
