Tranny blanket for 4L60E
Old 07-03-2004, 06:44 PM
badass 2002 z28's Avatar
Default Tranny blanket for 4L60E
Anyone running one with a 4L60E? I've heard they don't fit without moddifying the firewall....
I don't want to buy one only to find out that it doesn't fit
Old 07-04-2004, 07:43 AM
no one has any idea?
Old 07-04-2004, 04:47 PM
SmokingWS6's Avatar
Maybe they mean the metal trans sheild won't fit? I'd think there's enough room for a blanket, although they raise the trans temp
Old 07-06-2004, 09:07 PM
2001-WS6's Avatar
The standard trans blankets fit fine without any modifications. It's the trans shields that may require some banging for fitting purposes.
If you run a blanket full time on a daily driver, make sure you have a Trans temp gauge mounted to monitor temps properly. The blanket does reduce the airflow over the trans which means slightly higher temps in some cases depending on your converter choice. I was seeing an additonal 10F temp increase after I put it on last summer.
So I mounted one extra B&M cooler in series which took car of that and made for 180F max on hot stop and go construction days on the city streets.
Rick
