How hard is Trans-go to install yourself?
I just ordered a converter kit with a trans-go kit and a tranny cooler. I was wondering how hard the trans-go shift kit was to install yourself. Also, with the kit i asked for a vig 3200 stall... is this going to be too small? There will be a cam comming in the future, and im going to be mad about this small of a verter later?
Thanks alot.
Bryan.
Thanks alot.
Bryan.
your gonnalove the converter, but its gonna flash closer to 3600-3700
definately plan your cam around this verter, or you might haveta get it reflashed depending on what cam u decide. if your are mechanically inclined then i would say try the TC install, but im not sure about doing the shift kit install. i have heard they can be difficult. with that package you got im not sure what cooler comes with it, but i started out with a 19k cooler and ended up goin with the BIG one the 28k. if the trans starts to run warm get A fan switch. its a LIFE SAVER!
J
J
