manual valve body for 700r4/4L60 ?
Old 07-12-2004, 08:13 AM
GreekZ's Avatar
Default manual valve body for 700r4/4L60 ?
I want to install a manual valve body for a 700r4 tranny
Anybody know any companies that sell them?
Thanks,
Andrew
Old 07-12-2004, 08:52 AM
TeamTripp's Avatar
The TransGo 700-2&3 kit has a "stick shift" option. You MUST manually shift through the gears because it will be in whatever gear you select. You can upshift and downshift at will.
Old 07-12-2004, 11:12 AM
GreekZ's Avatar
Thanks for the info! Do you know if I will be able to delete the tv cable
with that transgo kit? The main reason I want to do this is so I can
remove the tv cable.
Old 10-19-2004, 03:23 AM
OldSchoolSleeper's Avatar
TCI makes a reverse pattern manuel valve body for the 700R4. I have one it mine and love it! It is supposed to help the transmission hold up to more abuse as well...
Old 10-19-2004, 07:47 PM
Restricted User
Automatics's Avatar
You do not want to eliminate the TV cable, as this controls line pressre. By diconnecting the TV cable you would have to have it set at WOT all of the time, and this will produce harsh to possibly brutal part throttle shifts all of the time & wear out the front pump at a much quicker rate.
