speedometer problem
speedometer problem
my car all of a sudden has a problem where the speedometer is delayed and slow. I have a 98 trans am a4. when i start to speed up from a stop the needle goes up very slowly and has about a 2 second delay. then when i stop it does the same thing. i took it into a shop and they said its either the gauge cluster or the speedo sensor. whats do you guys think and what should i try? also if it is the speedo then wouldnt my "check gauge" light go on?
