Tranny Question
Old 07-18-2004, 01:25 PM
Black 98 T/A's Avatar
Default Tranny Question
My friend rachel has a 01' honda acord four dour sedan with 20k on the clock. When you sit on a hill fully stopped and take your foot off the brake it rolls back and stalls out. I know this is not right
Also the rpm gauge needle sort of hops and drops when the accelerator is released. The tranny shifts just fine except some times it slips when going from a stop for a split second.
What is wrong with the tranny?-i'm pretty sure it will need rebuilt but any help is appreciated.
Old 07-18-2004, 07:23 PM
Ragtop 99's Avatar
he may have a motor issue if his rpms are bouncing around.
Old 07-18-2004, 10:57 PM
Restricted User
Automatics's Avatar
Some automatics do this. As the vehicle starts to go backwards, the input shaft starts to turn in the other direction, thereby bringing the stall down, then when low enough, will eventually kill the motor.
Old 07-19-2004, 12:00 AM
so is an accord supposed to do this? it just dosn't seem right to me.
what type of motor issue do you think it may be with the rpm's bouncing around?
again thanks for ya'lls time and i appreciate your help.
