Do you have to lift off gas to shift a TH400, like a manual?
Old 07-22-2004, 11:30 AM
MeanWS6's Avatar
Default Do you have to lift off gas to shift a TH400, like a manual?
Do you have to lift off gas to shift a TH400, like a manual? Or is that why you have the benefits of an auto with the benefits of a manual all in one?
Old 07-22-2004, 11:35 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
No you can keep it floored thru the entire pass.
Old 07-30-2004, 10:41 AM
MeanWS6's Avatar
what about street/hwy driving, lets say from a 40mph roll and you wanna go WOT - do you just drop it down a gear and let her rip at the same time. or even passing somone on the freeway. if so, what if your timing is off between your foot and shifting - kaboom??
or are roll races out of the question with a TH400
Old 07-30-2004, 11:44 AM
cablebandit's Avatar
a turbo 400 will basically do wtf you want it too. It is a badass transmission. I had several on 1st-2nd gen firebirds and NEVER had a single problem.
Old 07-30-2004, 02:26 PM
stangeater01's Avatar
cablebandit is right do wtf you want with it i like mine because i can put it in first drive and let the rpm's climb then let off and in 1st the trani will not re-engage until you hit the rpm's you stopped at so in other words it basically stalls till you hit that rpm so it jumps hard when you nail it
Old 08-06-2004, 08:54 PM
MeanWS6's Avatar
ok, so when driving on the street, say pulling up to a stop light do you have to manualy downshift her into 1st?
Old 08-06-2004, 10:03 PM
Colonel's Avatar
If you have a manual valvebody, yes. If not, no.
Quick Reply: Do you have to lift off gas to shift a TH400, like a manual?
