Oops, 4L60E truck vs. FBody?
Old 07-23-2004, 03:44 PM
Terry Burger's Avatar
Default Oops, 4L60E truck vs. FBody?
I got a rebuilt 4L60-E tranny for my Z28, but just realized the tailshaft doesn't have torque arm mounting holes. I assume that means it was from a non-Z28 application.
Other than the tail shaft, are there any other differences between the two?
Old 07-24-2004, 12:41 AM
CamaroCain's Avatar
a couple, the trucks also have the PRNDL switch mounted to the trans, where the
f-body has it mounted to the shifter. I dont believe the shift lever is any different though. The trans pan on the truck is 1 qt extra and has a drain plug in it. which also means the trans filter is a little different. Other than that i dont think there are any differences. Hopefully there will be a few replys if there are.
Old 07-26-2004, 01:52 PM
cablebandit's Avatar
the lever that selects the gears in the tranny is longer on the truck. I swapped mine out...easy to do if you haven't installed the tranny yet...and tailshaft housing.
