Help with a New Vig 2800 and a Transgo Shift Kit
Old 07-24-2004, 11:12 AM
Honez's Avatar
Default Help with a New Vig 2800 and a Transgo Shift Kit
This week I had a Vig 2800 and a Transgo shift kit professionally installed and now I have a few questions.
First off the tranny isn't working right so they are still working on it. It currently won't shift out of second gear. What's strange is that sometimes it works and sometimes it won't. If you turn the car off and restart the engine it might shift fine. Turn it off again and it might not shift out of second. What do you guys think is wrong? Next when it did work right the Vig 2800 seems more like a 3200 or 3600, is the 2800 suppose to be that loose?
Old 07-24-2004, 11:52 AM
James B.'s Avatar
Valve body needs to come back out and be inspected for debris/trash and properly cleaned. The spearator plate gaskets should not be reused even though the ones in there are just a few days old. The 3-4 clutch valve and solenoid is where I'd be looking.
A 2800 converter should not be stalling up to 3600.
Is there a possibility that a fluid problem exists? Too low? Clogged lines? Insufficient fluid in the converter will cause it to stall higher than its rating. It will whine and overheat too. Low fluid could cause the 3-4 clutch issue as well but it would have to be VERY low.
As far as testing your stall speed on a trans having problems, do not do that. You already know the 3-4 clutch pack isn't engaging. If the 3-4 valve is modulating partially and you are getting any kind of partial apply to the 3-4 piston it's just going to overheat the clutches and steel plates. Once that happens in a 4L60 the warpage of the steel plates creates hot spot that rapidly burn off the clutch materials. Then you'd need a full rebuild.Take it easy and get it worked out before testing your converter - it'll save you headaches, downtime, and money.
Old 07-24-2004, 12:45 PM
Honez's Avatar
The fluid looks fine with regard to the dipstick that was the first thing everyone checked. Thanks for the feedback.
Old 07-24-2004, 04:27 PM
4mula's Avatar
vig converters are underrated.
my buddies is a vig3200 and really stalls at 3800.
Old 07-26-2004, 12:24 PM
Silent but Violent's Avatar
My PI 2800 felt alot like stock. Awesome verter though. Ran 12.0's w/ it.
Old 07-27-2004, 06:44 AM
ArmyVette's Avatar
JamesB hit the really important stuff. The newer trannies are VERY sensitive to low fluid levels. Also, with the Transgo kits, you need to replace the 3-4 accumulator they provide (it's a plastic POS) with the aluminum one you can get at your local GM dealer for about $4. The plastic one will fail -- quickly.
Also, have you retuned your PCM to turn torque management OFF? That'll help your shift performance as well.
Hope this helps.
