TH400 guys: Which cooler are you using?
Old 07-29-2004, 09:27 PM
Woody's Avatar
Default TH400 guys: Which cooler are you using?
Well, just like the title says, what coolers are you guys using? I've got a B&M 24000 that I used w/ my 4l60e, but I am wondering if I should get something a little bigger. I have a 4000 stall Hughes converter and a trans brake. Thanks fellas.
Old 07-30-2004, 07:06 AM
Tim98TA's Avatar
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
I used my stock cooler lines which run through the stock cooler as well as a B & M 24kgvw cooler.
Old 07-30-2004, 09:02 AM
12secSS's Avatar
I will be running a thermostatically controlled B&M unit, it has the built in fan.
Old 07-30-2004, 02:29 PM
stangeater01's Avatar
i have the race b&m for my 400
Old 07-30-2004, 02:37 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
I have the B&M 28,000 GVW Racing Trans Cooler.
11x8x1.5
Old 07-30-2004, 04:21 PM
Spl170s's Avatar
So, when you go Th400, are you able to just hook up the factory cooler lines from the old 4L60 right into the Th400? Are the connections and such the same? Or does this require changing anything?
Old 07-30-2004, 04:42 PM
12secSS's Avatar
The OEM line going into the trans (from the 4L60E) do not hook up to the TH400. The TH400 uses threaded ends, where as the 4L60E uses clips to retain the lines.
Old 07-30-2004, 04:52 PM
Spl170s's Avatar
If you removed the threadeds ends from the 4L60, could you install those into the 400 then still use the facotry lines and all?
Old 07-31-2004, 02:45 PM
The Bull
DERTY's Avatar
I use a Derale 16 pass cooler with a 10" fan and a inline thermometer for the fan. Temps are always perfect.
You can take the stock lines and put a b-nut on there with a flare if you want. But it's way easier to just replace it with two sections of -6 AN braided line.
Old 07-31-2004, 04:44 PM
Tim98TA's Avatar
Yes, that is what I did. You have to tweak(bend slightly) the lines a bit at the ends to allow them to line up with the TH400 holes, but it all works fine.
Old 07-31-2004, 11:46 PM
Spl170s's Avatar
okay, that is what i needed to know.....thanks!
Old 08-01-2004, 01:43 AM
White98Z's Avatar
What about if you are going from a 6 speed?
Old 08-01-2004, 02:00 AM
BIGBOS's Avatar
Derty, what did your temps get up to normally crusing around, and what were they at after a run or two....
Mine are usually at 160-180 on the street, depending on how hot it is......recently on a really hot day it got up to 210 cruising, I have a big cooler, I'm thinking about putting a fan on it, I'm also thinking I might have a converter problem......
After each pass at the track the trans went from 180 to the 210-220 area.....
Old 08-01-2004, 09:44 AM
The Bull
DERTY's Avatar
Going from a 6 speed you just need to run some -6 lines. You don't have any factory cooler stuff to mess with.
On the street my trans never went above 190. In fact, it cooled so well that it takes a long time to really heat up. At the track it does about the same as well, climbs to about 190 at the end of a couple runs. I can sometimes hot lap it and not see any real temperature rise until the third pass or so. Needless to say, mine stays rather cool. When it gets cold here (in the 40's) I have a hard time even getting the temperature to go above 100. I drove it from my house on the freeway for about 20 miles and the temperature never really climbed at all until I let the car idle at a stop for a little bit.
Old 08-01-2004, 10:02 AM
Woody's Avatar
I'm definitly going to have to get me one of those Derale coolers.
