B&M 28,000 GVW or 24,000 GVW?
Old 08-04-2004, 10:48 AM
ShadowLightCSU's Avatar
Default B&M 28,000 GVW or 24,000 GVW?
Is there any reason why I wouldn't choose the 28,000 GVW over the 24,000 GVW tranny cooler?
Seems only Jegs carries the 28,000, is there a reason for it?
Old 08-04-2004, 11:52 AM
heyitsTaJay's Avatar
go big or stay home. i had a 19k and it didnt do the job. driving conditions constantly change so i felt much safer with the 28k there. i would recommend the 28k hands down
Old 08-05-2004, 12:00 AM
Ed Blown Vert's Avatar
24K is fine. I run one.
Old 08-05-2004, 02:01 AM
MeanWS6's Avatar
when it comes to trans coolers, bigger is better
some even run multiple coolers
Old 08-05-2004, 06:30 AM
ArmyVette's Avatar
I'm not sure you can "over buy" a tranny cooler. More cooling is better.
Old 08-05-2004, 09:17 AM
12secSS's Avatar
The 28K model (p/n: 70266) has 1/2 NPT threads on it and does not come with any mounting accessories, it is just a cooler for use with AN fittings. The 24K is the one most every one buys (that online vendors sell), it comes with the installation hardware for a universal fit. If you want to custom make the lines, go with the 28K. If you want something that will 'bolt-in' without requiring any parts, go with the 24K (model #70264).
Old 08-05-2004, 09:45 AM
That's what I wanted to know, thank you. Is there any reason not to go with the frame mount one?
Old 08-05-2004, 11:01 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I have the 28k gvw race version it's a custom install for sure.
Old 08-05-2004, 11:17 AM
Blue2002SS's Avatar
24,000 here and works great
Old 08-05-2004, 11:37 AM
Moderator
jimmyblue's Avatar
The "frame rail" coolers look like a sweeter install
and you can unshroud the condenser / radiator,
but they have a much lower rating and surface area.
Quick Reply: B&M 28,000 GVW or 24,000 GVW?
