Need Advice
Need Advice
I went to a well known tranny shop and I was telling the guy I want a 3000-3500 stall. He said that, that was to much stall for my cam(224/228 567/571) b/c I was way over the powerband of the cam and I need something b/t 2000-2500. He claims the converter needs to start with the powerband of the cam. Any thoughts please???
Originally Posted by 4mula
hes full of ****. the stall you want will be just fine
Actually the guy is correct - in one sense. You need to match your power band. He just doesn't know the power band of our cars. If your peak torque is 3500-4000 (which most of our cars are) the 3500 is perfect. When was the last time you seen one of our cars (even stock) have a torque that peaks at 2000?????
The 3500 will serve you well.
David
David
David
David
Pontiacerator
A lot of guys in shops out there only know the SBC - when it comes to the characteristics of the LS1/6, they're clueless. Guys with traditional Pontiac experience know the problem well - you're constantly fed nonsense based on what works with SBC's. You will get better advice on anything LS1-related on this board than anywhere else.
