Converter Question??
Im looking into getting a T-rex cam and its states that you need a 4000+ converter..I called a guy to get some prices and he basically told me that i was crazy since im a daily driver. He said it would blow my transmission. . Is this true? anyone got a 4000+ converter and have a stock tranny?
Originally Posted by Need2gofaster
Vig 3800 in mine for a year now.......Love it! It just takes some getting used to. Just put you car in D unless you are going faster than 55. It will lock up the converter faster and make it more street friendly. Temp gauge is a good idea(almost a must)And make sure you get a trans cooler. Mine was running at 210 in the city and now with my B&M in dosnt get above 180.
He means a tranny temp guage if I had to guess.
You can run a 4000 stall in a A4 and you will have a chance of your tranny breaking.
The 4L60E is about the biggest POS in the GM plant, goes right along with the 10 bolt and the power window motor's.
Any converter can cause tranny failure, its all a matter of luck. Make sure you add a HUGE tranny cooler to be safe.
