A4 Flywheel Torque specs and use locktight or anti seize??
Old 08-31-2004, 05:58 PM
speedo's Avatar
Default A4 Flywheel Torque specs and use locktight or anti seize??
Got a new TCI SPI fly wheel for My A4. I can't find any Torque patterns or specs in the search or install guides. Do I use ani seize or locktight and if soe what color locktight...
Anyone have a clue....?
Thanks for any info..
Old 08-31-2004, 06:09 PM
Mean Green z28's Avatar
Use blue Locktight with about 55-60lb of torque
Old 08-31-2004, 08:37 PM
DEEZ98Z's Avatar
What Tuan said.... and here is a awesome websight with all the torque specs in there too
www.ls1howto.com
Old 08-31-2004, 10:54 PM
12secSS's Avatar
Actually you want to use Loctite red, not blue. Blue is a medium strength adhesive, used for fasteners that you may need to reinstall/retorque. Red is a high strength adhesive for fasterners you do not want to come loose at all, especially under vibration conditions ... like a flywheel/flexplate.
