Tranny Temp Gauge
We run the autometer trans temp manifold inline with the cooler lines, it has a provision for the temp sender. with the rubber lines of the aftermarket cooler, it makes it extremely simple.
Clint
Clint
Clint
Clint
Clint, can you explain in a little more detail how this is setup?
8 second mod
Mike, your tranny has a spot right on the side, it should be the drivers side. it has a plug in it, pull that plug, and thread the fitting right in. My th-400 was the same way. much easier then tapping the pan. you might not even have to empty any fluid.
