Stall converter install, how much should it cost?
Old 09-22-2004, 01:21 PM
t1blackout's Avatar
Default Stall converter install, how much should it cost?
How many hours should it take a professional tranny guy to do my stall converter install? Is there anywhere I can go to get exact directions that I can print out and hand to him?
Keep in mind that he has to install:
ST3500 Stall converter
B&M Tranny cooler
Transgo shiftkit
Temperature Guage
He quoted me 600 dollars (@ 60 per hour). Is this insane? Does anyone know someone that will do it cheaper? I live in central/Northern Virginia.
Old 09-22-2004, 01:52 PM
Devilss02's Avatar
The price does seem a lil high i believe it should be around $450 with everything you have. Not every trans guy installs trans-gos try to find someone who does.
Old 09-22-2004, 02:17 PM
68birdls1's Avatar
cost- nothing! do it your self but $60 bucks an hour does seem a lil high!
Old 09-24-2004, 05:40 PM
REDLV SS's Avatar
To install my converter, tras-go shift kit, cooler and all fluids and filter was only $350.
$600 is outrageous in my opinion.
Old 09-24-2004, 06:15 PM
sfwalters's Avatar
You should be paying 350-450 for everything. Hourly rate should be from 35-50. FIND SOMEWHERE else even if you have to wait longer or drive farther.
Old 09-25-2004, 10:55 PM
jmil1974's Avatar
Hourly rates will vary depending on your location and economy. Here in Houston, rates range from $50-100 an hour, depending on what location in town and how good the shop is. If it's TOO cheap, make sure you know what you are getting. 10 hours is not out of the realm. It's about 7.5 to straight R&R the typical 4L60e. Sounds like he's not cutting you any breaks but not quite bending you over either. What do other (tranny) shops charge. What kind of warranty does he offer? How long in business? Good reputation? If all these answers are favorable and comparable, I'd say it's realistic. Don't let someone across the country tell you what it should cost. How much you trust this shop and it's work/warranty is the bottom line.
Also keep in mind, he's charging book time (like alldata, etc.) not punching a clock. It has pros and cons.
Old 09-26-2004, 12:21 PM
Need2gofaster's Avatar
do the guage and cooler yourself and save yourself some money..they are both easy to do. 600 is insane to pay for that.
Old 09-26-2004, 03:24 PM
Mooobunnny's Avatar
Mine was 300 including everything
Old 09-27-2004, 07:20 AM
STF Veteran
99-LS1-SS's Avatar
Who did your Chris?
Old 09-27-2004, 07:57 AM
Ragtop 99's Avatar
$250 (backyard special) - $400 (shop) for everything is reasonable in our area.
Sent you an e-mail with the name of a good local shop.
Old 09-27-2004, 09:42 AM
ActionJack's Avatar
I was quoted 390.00 to install convertor and trans cooler and shift kit. 600.00 is too much IMO. I am sure there is someone on the site in your area that has had it done for less and could refer you.
Where are you located?
Old 09-27-2004, 02:25 PM
t1blackout's Avatar
Fbody central said they would do the stall for cheap but they wont do the transgo because they say it sucks...
Old 09-27-2004, 02:33 PM
2MuchRiceMakesMeSick's Avatar
600 is pretty redicuolous. Where are you located? I may be able to get it ALOT cheaper if your around DFW
Old 09-27-2004, 02:38 PM
t1blackout's Avatar
northern va
Quick Reply: Stall converter install, how much should it cost?
