Stall RPM question with STS turbo....
Old 10-06-2004, 06:22 PM
ThaLS1Kid's Avatar
Default Stall RPM question with STS turbo....
I am planning on getting a STS turbo kit for my '98 A4 SS. Eventually it will be a H/C/I car along with the STS, but for the time being it will be turbo only. What would be a good stall RPM to compliment the turbo? It makes full boost around the 3000 RPM range and max torque should be in the 450ish range at about 4-4200 RPM.
Thanks in Advance!
Jeremy
Old 10-06-2004, 07:38 PM
68birdls1's Avatar
why dont you get head/cam then turbo?!?
Old 10-06-2004, 08:21 PM
Ragtop 99's Avatar
About a 3600 stall would work well.
Old 10-10-2004, 09:41 AM
2MuchRiceMakesMeSick's Avatar
:stuipd: I agree. You can use the chart below to help you out more.
http://www.converter.cc/converter_choice_guide.htm
Old 10-12-2004, 10:25 PM
ThaLS1Kid's Avatar
Thats odd, I talked to PI about a Vig. converter and they rec. a 2400-2800 and by that chart Yank is rec. a 3400-3600. Anybody know what would cause such a drastic difference, or is it just manufactor opinion?
Old 10-13-2004, 09:55 PM
ThaLS1Kid's Avatar
Anybody...
Old 10-14-2004, 09:01 PM
ThaLS1Kid's Avatar
Once Again...
Old 10-14-2004, 09:16 PM
BigPlanTransAm's Avatar
if youre launching under full boost you will probably want a full suspension and sticky *** tires. if you dont have any, or only some, of that then you probably want to launch a little below your boost threshold in order to gain traction.
when you do the h/c you may want a higher stall to compliment your new powerband and again: the suspension and tires will do wonders for your traction.
