Daily Driver Mod Recommendations Please
Lets see. I just bought my Z in June and have the mods listed (Thanks to Ls1Tech). Its got the 2.73 gears in it right now, and according to most of you A4 guys out there a new TC is the way to go. I will be getting some Jet Hot long tubes this month, then will jump on a new TC and set of gears to go with it next month and need to know whats involved.
My car is my only car and daily driver, so i dont want the gas mileage to dip too low and i dont want it to be uncontrollable, so i need some advice as to what brand/stall to look for and what size gears to go with to help my street performance. I would like to get a good increase in performance without pushing it. I drive about 40-50 miles highway a day. Thanks techies!
Get a vigilante 3200 & trans cooler. IF you want a cheaper stall get a tci 3500. I prefer the Vigilante convertors. As for gears i am not sure most people switch to 3:73s
My car is streetable/daily-driven and I went with a Super Yank 3500 along with a Stage2 TransGo shiftkit. In terms of gas mileage being one of your restraints, I'd go up to 3.42's max...some may not agree, but that's my POV. I have the stock 3.23's with my setup and I ran a 12.3 this weekend on baby nittos, not stalling it up at the line.
Moderator
My TCI3000/2.2 cost me no gas mileage and is very
streetable (call that a plus, or a minus, as you like).
I just went up to 3.42s and the difference from 3.23s
was not too noticeable; under the "every little bit helps"
theory you ought to go for a set of these, used, low
miles.
miles.
man get yourself a yank, even if your not gonna race it, it is just a better built convertor! check out there website it is on the right hand side since they are a sponser. but if your just lookin for a cheap way to get some extra, then a tci or a vig will do you great!
So whats involved with installing a converter? I am supposed to get tranny cooler too right? Will i need some tuning for the transmission as well? and after i get a set of gears will i need some more tuning? Would it be better to have both installed at the same time and then tuned?
Yes you should get a good sized trans cooler, and I would also recommend a trans temp gauge if you can fit that into the pricing.
Yes I would wait till you have done both gears and converter and then get it tuned.
I would do a 3200-3800 stall w/3.42 gears. My car ran pretty good with a Vig3600 and 3.42 gears in the past. We pulled some high 1.5 60 easy and the car was putting down very low 12's and high 11's with just bolt-ons. But there are many converter options out there. Check out our sponsors Yank & TCI---------->
go with at least a 3800..they are very streetable once you get used to it. you will regret it of you go to small. my 3800 gets great milage withcity driving
Moderator
You really need to consider how you are going to tune,
for the changes you plan. Headers, and the converter,
both will want some tuning. I would actually put the
tuning bit ahead of both, because the stock transmission
shift programming is really lame and you probably stand
to gain more -street- horsepower / acceleration from
a decent set of shiftpoint settings (WOT and part throttle)
than you do from headers, and properly managed shifting
will do better at getting and keeping you in the powerband.
A higher stall, higher STR converter will pay off, off the line
and "fill in the gaps" when shifting is not what it should be.
And if you have moved to a peakier HP/TQ setup the
converter can keep you on that peak. But at the same time
a converter "exposes more suckitude" in the stock program
transmission settings.
How are you going to get long tubes past Cali smog test?
If you have a way, probably best not to say But you may
have a problem there and want to reallocate your mod money
to stuff that won't bite your *** regulations-wise.
Pontiacerator
[QUOTE=jimmyblue] I would actually put the
a decent set of shiftpoint settings (WOT and part throttle).
[QUOTE]
I went against the grain and did gears before converter because most of my driving is in town and the 2.73's were a drag. If I were you and doing a 50 mile commute, I would start with the converter, do some tuning, keep the high gears, and see how I liked it.
[QUOTE]
I did my track performance mods in this order (And was very happy with it, and would do it again just the same).
1. Lid :
2. Smooth Bellows:
3. 3.73 Gears (Then needed Drag Radials):
4. Predator Programmer
5. BFG Drag Radials
6. Longtube Hooker Headers with ORY
7. ST3500 Stall Converter (HUGE!!! AWESOME!!!)
(Got B&M Tranny cooler and TransGo shiftkit, also got a temp gauge.)
I would definatly do things in that order. the gears helped me almost as much as the stall converter (not as much, but diddnt have as much of a toll on drivability either... I think you should do gears, then the Stall. )
1. Lid :
2. Smooth Bellows:
5. BFG Drag Radials
