Trans Temp Gauge Install
Old 10-10-2004, 02:10 AM
DOUBT IT's Avatar
Default Trans Temp Gauge Install
I'm planning on installing a trans temp gauge pretty soon, and I've seen something in the catalogs that I'm curious about. There's a little gizmo that Auto Meter offers called a "temperature manifold", and I've read that some late models require it to hook up the gauge, I was wondering if I would need that for my 4L60E. Also any info on where to hook up the gauge would be much appreciated.
Old 10-10-2004, 07:50 AM
2MuchRiceMakesMeSick's Avatar
Are you hooking up an electric or mechanical guage?
Old 10-10-2004, 08:06 PM
DOUBT IT's Avatar
Electric, sorry, shoulda listed that in the post.
Old 10-11-2004, 09:52 AM
ricker6869's Avatar
I am also interested in installing one of these...a friend of mine put a gauge in his pick up (4l60e) on a pressure service port on the driver side of the transmission(above linkage)..said the sender fit perfectly.???? I dont know if the LS1 have this port, although same tranny??(4l60e)
Rick
Old 10-12-2004, 03:53 AM
slick98ta's Avatar
Rick
I have mine put in that same port with no problems
Old 10-12-2004, 11:41 AM
Black 98 T/A's Avatar
yup just screws into the port...
Old 10-12-2004, 06:42 PM
DOUBT IT's Avatar
I guess that I'll put my sender in that port. Much appreciated folks.
Old 11-28-2010, 07:40 PM
SILVER 2288 SS's Avatar
Location: boaring place where theres more cows than people
whats the easiest way to run the sender tube to the gauge
Old 11-28-2010, 08:29 PM
SS SLP2's Avatar
Use Electric, no need for tube only a single wire to sender , several wires at guage, I for get the brand I used , it is programble to flash at any set temp digital guage and sending unit from summit about less than 1 bill. I mountrd it in the pan but you may mount in the port
Johnny
Old 11-28-2010, 10:43 PM
01ssreda4's Avatar
Do not run a tube of trans fluid into your car......ewww
Old 11-29-2010, 10:18 AM
i get a pretty good deal on autometer at my work so im gonna end up getting an autometer trans tem gauge. my question is how would u run the wire to the sender or do you have to run a wire into the car for it idk ive never used an autometer electic gauge before
Old 12-10-2010, 07:25 PM
DOUBT IT's Avatar
Put the sender in the pressure test port. It's on the driver's side of the trans, above the shift linkage. Use red loctite or teflon tape to seal it.
Crimp or solder a ring terminal onto a wire, and attach to the end of the sender. Run wire to appropriate terminal on gauge, and viola. Temp gauge.
This is how I did mine 6 years ago, and it's still going fine.
Old 12-11-2010, 01:21 AM
01ssreda4's Avatar
Holy crap a 6 year old thread
Old 01-07-2011, 10:17 AM
JustAFooL's Avatar
I have a trans temp gauge, af, and the one that has the digital tach with shift light in it. Got them all for Christmas but havent even taken them out of the box.
I'm sure they all have a wire for lighting. Where does everyone run this to?
Old 03-05-2011, 09:16 AM
JustAFooL's Avatar
I just got my autometer trans temp and was getting ready to hook it up when I found this 6 year old thread..
I know what the sender is, but I can't figure out how it goes into the pressure port. Here is a picture of the sender they send, i'll just label them 1-3 from left to right for easy reference. Both 2 & 3 will screw into #1. How am I supposed to do this?? Once I get the sender figured out, I'll be fine. I've done got the gauge mounted and the wires ran for it. BTW, sorry for the shitty pics. I'm in the garage now hookin up my other DPSS gauge and needed thw quick fix.. Thanks!
Old 03-05-2011, 10:19 AM
Moderator
Vince B's Avatar
If using the pressure port you will just use the main fitting on the left. I personally like to see the sender mounted in the transmission pan or in the return cooler line. I have seen cases get damaged or the sender destroyed when it bottoms out on the inside of the case. When the sender is over tightened it will mushroom the end of it. When this happens if it has to be removed it will normally break the end of the sender off or take out the pipe threads in the case. If you do use this port please do not go all gorilla when you tighten it down. Good luck with your install. Vince
Old 07-16-2011, 12:17 PM
White94Bird's Avatar
Gonna bump this, I have a autometer trans temp gauge eletric..
i have it wired up but I can't get it working. the back light will light up but the needle will not move.
Quick Reply: Trans Temp Gauge Install
