do you have to upgrade the trans filter when using the deep trans pan for the LS1's?
i have a tci deep transmission pan and i was wondering if you have to upgrade the transmission filter? do you use the stock trans filter one or do you have to use a longer transmission filter with a longer neck due to the larger pan?
my tci trans pan didn't come with an extension, which filter would be the longer neck filter? would a trans filter from a 4l80E work? is that a longer neck base filter?
Moderator
On my TCI super-deep pan, it came with four cast-in
"prongs" to support the stock F-body filter. I ground
them down about 1/2-3/4" so I could use the "truck
filter" and have the pickup that much deeper in the
juice, so as to eliminate any cornering / acceleration
pickup starving (yeah, I should be accelerating that
hard... heh).
hard... heh).
