4l60e: "Corvette servo"?
Old 10-28-2004, 09:24 AM
Slart's Avatar
Default 4l60e: "Corvette servo"?
Hi,
I have a 2002 ss w/ a 4l60e and I had problems with the 1-2 shift, so after reading a bunch of threads here, and talking to a transmission guy, I put in a larger reverse boost valve, turned the EPC 1/8th turn (which resulted in 205 PSI at WOT), replaced the 4th gear servo with a "super servo", and replaced the fluid with redline racing ATF.
Now the 1-2 shift is fine, but in 4th when I accellerate even lightly it slips.
I suspect that the problem is the 4th gear super servo. The instructions said something like "fits up to 1999 4l60", and I've got a 2002. Anybody have any input?
I'm thinking of replacing it with a "corvette servo", but it seems odd, since corvettes and f-bodies both have the LS1 and a 4l60e, it seems that corvettes and f-bodies would both have the same servo. Do these cars already come stock with the corvette servo?
Steve
Old 10-28-2004, 12:40 PM
Rock-On's Avatar
Default hey
Yes to the vett servo....you have one from the factory. Hope this helps...Dave
Old 10-28-2004, 12:49 PM
Slart's Avatar
Thanks much.
Do you think my 4th gear slip problem could be from using a servo that "fits up to 1999 4l60" in my 2002 trans?
