Tranny fluid, should it be changed?
I got my PT4000 installed and they said my fliud was a little burnt, and in a little while my tranny will take a crap. They also said it wouldnt be a good idea to change my fluid as it will make the tranny go sooner. I thought I have heard that this is true, but I wanted some opinions. Looks like Im saving up for a new tranny.
My .02 cents..... I traded for a mercury sable a few years ago. The guy had just decided it needed the trans fluid changed. When he let it down off the jacks it wouldn't pull out of it's tracks. I did everything I could and never got it going til I put in another transmission. I've since been told that if the fluid is changed regularly then keep it changed and it will extend the life of the transmission, if it has high miles and has never been changed then don't bother or you'll be flushing out the gunky glue which is holding it together. I guess this will be as true on GM trans as well as fords.
I'm not a transmission mechanic so I can't say, but this has been the opinion of several people I've talked to.
Pontiacerator
Originally Posted by Randyj
My .02 cents..... I've since been told that if the fluid is changed regularly then keep it changed and it will extend the life of the transmission, if it has high miles and has never been changed then don't bother or you'll be flushing out the gunky glue which is holding it together. I guess this will be as true on GM trans as well as fords.
