Car stalling when its put in gear?
Old 11-29-2004, 10:33 AM
ApacheDrill's Avatar
Default Car stalling when its put in gear?
I am having problem with my car. The car is tunned and runs great. When i go to put it in gear it falls on its ***. Sometimes i can hold the brake, give it a little gas and roll it out.Also it has done the same thing when stopped. Is this a transmision problem or still a issue with the tune etc? It drives fine but once in awile it slips a little like up hills etc.. It has 57,000 miles on the tranny and plenty of passes and nitros ran through it. Just looking to see if i am on track with this. I am almost postive its the tranny, just looking for some reasurance before spending the cash on a built one. Any help is appreciated..Thanks In Advance
Old 11-29-2004, 01:58 PM
94form2000z's Avatar
Tune. Possibly just need to raise the idle speed. Tranny will not make it die unless of course the idle is to low for the load when engaged.
Old 11-29-2004, 02:52 PM
timelord's Avatar
Is the TC locked up??
Old 11-29-2004, 04:02 PM
68birdls1's Avatar
i would say that your idle is too low. try raising it up manually and see what that does! not to much though lol
Old 11-29-2004, 06:39 PM
Rock-On's Avatar
Default hey
I'm with timelord....I'd check your lock up on your verter....hope this helps ...Dave
Old 11-29-2004, 07:06 PM
K9 Pusher's Avatar
Mine did this as well. I had my idle bumped to 875 during tuning and now I have zero problems. Good luck sorting it out.
Old 11-29-2004, 07:09 PM
I havent really got use to the converter yet and i know this sounds stupid, but how do you tell if its locked or unlkocked? How do you lock or unlock it? I thought about messing with the turn screw, but i wasnt sure if it was a good idea with it being tunned. It only acts up when its under load under idel conditions. The more i talk the more i am answering my own question. I think i need to figure out how to use this converter and read up on it a little more. I have just been driving it and not knowingly locking or unlocking the converter.. I know at some point the stock tranny is going away, but i dont want to mess with it till its shot. The trottle body was drilled when we did the heads and cam, not sure that matters with the turn screw.. Thanks Again..
Old 12-01-2004, 10:49 PM
luv_my_z28's Avatar
i have that same problem since my cam install. It doesn't do it all the time, just every now and then. My idle is at about 900-950 rpm from my tune and it still does it.
Old 01-17-2005, 01:39 PM
Silver02's Avatar
My car does this all the time when cold and occasionally when warmed up. I've got a pretty hot cam. Once the car is in gear, everything is fine. When I put it in gear the revs drop just like on all stock automatics and with the cam that sudden drop makes it fall on it's face. I was wondering if a stall converter would prevent the revs from dropping when I put it in gear?
Old 01-17-2005, 01:47 PM
Either you have a MONSTER cam or you have a bad tune. I cannot think of a cam that should not idle in an a4 with a 950RPM setting
A Stall does help tame a big cam down when at idle.
Old 01-17-2005, 04:18 PM
Silver02's Avatar
It idles fine. The problem only occurs when I put it in gear causing the revs to drop.
Old 01-17-2005, 04:39 PM
Believe that is handled by two different tables such as when the A/C is on. I had my car by X tuner. Idled ok but died in gear and when in turns. retuned by Y tuner and never had any issues.
Old 02-02-2005, 04:17 PM
Michael Ozorowsky's Avatar
Did you get a fix for this yet? I have same EXACT problem.
Old 02-05-2005, 03:11 PM
Silver02's Avatar
I had some more tuning done with ls1 edit and now it almost never does it. Just to be sure, I give it very light throttle when it's cold and I put it in reverse. I'm sure a stall converter would help a lot.
Old 02-06-2005, 01:46 AM
MNR-0's Avatar
Increase your Idle Air Cells when in Gear. Also check your O2 sensors are swinging happily at idle.
Old 02-06-2005, 05:30 PM
JEB99TA's Avatar
Possible answer: Mine did that when I had my cam installed and I was running NGK TR6 plugs. I changed back to TR55's and it helped, but, I still needed a tune. I had my car tuned and it helped, then, I put TR6's back in it. I think the TR6 colder plug with the .035 gap is what's causing the problem. I'll post and let you know as soon as I chnage back to the TR55's. Just my theory that seems to be the issue. Maybe yours is the same ... will let you know.
