how do you disconect the engine from trans
I have the engine out of the car and engine on hoist and trans supported on ground and I have taken all the bolts around the parimeter of the trans and the level tube is out. I can't get the trans to come apart any this else that I need to do? thanks for any help
no well im the idiot, you posted in the "auto" section..
well depending on the make, there should be a way to get to the flywheel/torque converter through an opening in the bellhousing at the bottom.. usually held on by just a couple small bolts.. hope that helps.
When I was doing one, the metal pins had corroded to the housings. I got a hand winch and hooked it to the tranny and rear axle, and started cranking. At the same time we where hammering in screwdrivers between the two housings. And I sprayed WD-40 into the holes in the hopes of breaking it free.
Eventually worked. Good luck
