Strange noise form gears
Old 12-06-2004, 07:31 AM
fa18007's Avatar
Default Strange noise form gears
Hello all,
I just bought an 02 Trans am A4 and I am new to this stuff. I am trying to learn as much as I can about this awesome car. I have been listening to the vehicle very closely for any problems. The only noise I hear that I don't know is normal or not is coming from what I guess is the transmission. When I am coasting at about 1-30 mph and step back on the gas, it makes a "clunk" noise as the car goes back into 1st gear. It seems like it jumps into first gear and gives you a little bit of a jerk. Is this normal or should I have it looked at?
Thanks,
Greg
Old 12-06-2004, 12:09 PM
Ragtop 99's Avatar
The car isn't going into first gear when coasting above 10 - 15 mph unless you are getting deep into the throttle. Some automatics hesitate for a split second and then shift hard if you are coasting then hammer the gas. However, if this happening at a light throttle, you may have something up.
The first thing to check is to make sure your fluid level is good and clear. If you have a lot of miles, you might also consider having the fluid and filter changed too.
Old 12-06-2004, 03:44 PM
fa18007's Avatar
The car does have a slight leak in the transmission which will be fixed soon. Is this the porblem? It is happening at mid throttle around that speed range of 10-15mph. What da y a think?
Old 12-06-2004, 04:16 PM
GT Griller's Avatar
Is it only when it shifts? My guess would be a tranny mount, but that gives more of a bang sound.
Old 12-06-2004, 07:08 PM
fa18007's Avatar
Yes it is only when it shifts. It is only when you are doing under 20 mph i guess. It is not loud at all but it just weird to me. The car only has 22k on it and is still under warranty.
