Shift Kit
Old 12-16-2004, 03:25 PM
mikes98z's Avatar
Default Shift Kit
I was wondering if it would be a good idea to go ahead and put a shift kit in my A4 because I need to change filters and fluids in it. Anyone have a good recomendation? It has the stock converter right now because funds are short right now to upgrade.
Thanks!
Mike
Old 12-16-2004, 06:17 PM
jxaxsxoxn's Avatar
You be in for a lot more work to drop the valve body and do a shift kit.
Probably have to remove the servo too.
It's not that bad, you should get some tuning done like shorten the 2-3 shift duration along with the shift kit.
I'd suggest a transgo kit.
Old 12-17-2004, 10:31 AM
BoonesZ's Avatar
its usually best to stick with electronic tunig unless you have heavy mods
Old 12-19-2004, 09:48 PM
Ratical's Avatar
[QUOTE=jxaxsxoxn]you should get some tuning done like shorten the 2-3 shift duration along with the shift kit.
QUOTE]
Do you know how I would you do this with LS1 edit. Both of my T/A's hesitate shifting from 2-3.
