Rebuilding my tranny. Need an honest opinion and some advice
Old 12-21-2004, 08:47 AM
TRYMYZ's Avatar
Default Rebuilding my tranny. Need an honest opinion and some advice
I am looking to rebuild my other 4L60e and was seeking some wisdom/advice. I have never rebuilt a transmission before, but have faith in my mechanical ability. People constantly say that it is difficult and not to attempt it. For those of you who have done it, is it really that hard ? I know the automatic transmission is pretty complicated, but with a good manual I am sure I can do it. So here are my questions:
1. Is there a good manual someone could recommend ? (this is a LS1 4L60E)
2. Are there any special setup instructions/measurements specific to LS1s ? (Pro Built I know you have mentioned something along these lines)
3. Will a TCI rebuild kit, Z-pak 3-4 clutches and shift kit be enough ?
4. Where can I obtain the modified "Shift Kit" for the LS1 4L60Es ? (another question for Pro Built)
5. Any common snags that first time builders usually run into ?
Thanks in advance
John
Old 12-21-2004, 09:10 AM
BigBake's Avatar
John, stop by and pick up my GM service manual, it it shows it all. You will not go wrong with it.
Oh yeah, and go vacuum modulated for your shifts, it will last longer and shift much more quickly.
Old 12-21-2004, 09:39 AM
WILWAXU's Avatar
John,
I use a great shop up here. Guy can normally turn it around in ~24 hours and is very reasonable. Give me a call, I'll give you details.
Old 12-21-2004, 10:17 AM
TRYMYZ's Avatar
Trent thanks for the reply. I have the service manual (thank god) for the car. Just thought maybe there was a step by step rebuild book for rookies. BTW the tranny works good, but doesnt like the 2-3 shift/3rd gear....lol Already knew that though. Other than that it works like a champ. John I will give you a call price is everything.
Thanks guys for the responses
John
Old 12-21-2004, 10:43 AM
BigBake's Avatar
John
Cool, I can also refer you to JoeC on our local board he has sucessfully installed a Transgo shift kit on his 4L60E, and can tell you all the little tricks and stuff that he learned from the install. Glad to hear that the tranny is good for getting around on, get your other one built up, and then you can build that up as a spare. Well now you know why I could never get a clean pass on a 150 shot, the sad thing is I ran faster on a 100 shot. The TH400 will have no problem
Old 12-22-2004, 02:03 AM
Restricted User
Automatics's Avatar
TRYMYZ, here goes.
1. Is there a good manual someone could recommend? (this is a LS1 4L60E) Yes, the ATSG build & update books are good.
2. Are there any special setup instructions/measurements specific to LS1s? Just the "modified" Trans-Go Performance Shift kit instructions, otherwise the same as the regular 4L60E.
3. Will a TCI rebuild kit, Z-pak 3-4 clutches and shift kit be enough? Use the Borg Warner Hi-Energy 8-clutch 3-4 setup.
4. Where can I obtain the modified "Shift Kit" for the LS1 4L60E's? At www.700r4l60e.com
5. Any common snags that first time builders usually run into? Have someone who is familiar with these units help you out on this. This will make things go a little smoother.
Old 12-22-2004, 05:33 AM
jxaxsxoxn's Avatar
Set the clutch clearances up to performance specs, not what the manual or the ATSG book says.
Old 12-22-2004, 08:08 AM
TRYMYZ's Avatar
Thanks for the responses guys, especially Dana from Pro Built Automatics. He spent a good 30 + minutes of his time answering all my questions and giving me advice. I am going to make this a long term project so I can take my time and do it right. Anyone who has ever worked on cars with me (WILWAXU) knows how meticulous I am. Thanks again guys.
John
BTW Does anyone have the specs on how the clutches should be setup for performance ?
Old 12-22-2004, 03:51 PM
Restricted User
Automatics's Avatar
Reverse/input .035-.060". Overrun, as is, Forward .025-.050". 3-4 .040-.055". Low/reverse .040-.075".
Old 12-22-2004, 08:52 PM
john kilgore's Avatar
Default 3-4
do you guys know about api and the huge 3-4 clutch pack he has?
Old 12-22-2004, 09:01 PM
jxaxsxoxn's Avatar
I've heard about it and refered to it at least once here, it got ignored as usual.
It uses 6 discs and has more friction surface than the typical 9 disc set up right? Do you have a link to it?
Old 12-22-2004, 10:24 PM
Faze2183's Avatar
is the z-pak good???
