Tranny cooler .. really necessary ???
Old 12-23-2004, 08:54 PM
JEB99TA's Avatar
Default Tranny cooler .. really necessary ???
With my setup:
If I do a transmission cooler, will it prolong the life of my tranny by much. Do you think it will give me noticeable performance/ET's?
Old 12-23-2004, 09:20 PM
69_YENKO's Avatar
Originally Posted by JEB99TA
With my setup:
I dont think you will see any performance gains, but your tranny will run much cooler which will prolong transmission life. my trans with stock converter, no cooler ran hotter then it does now with a 3,200VIG and B&M super cooler. not just alittle cooler, more like 40-50* cooler.
Old 12-23-2004, 09:36 PM
68birdls1's Avatar
if you are gonna spend the big bucks and get a yank convertor (or any convertor for that matter) then spend a lil bit extra and get the tranny cooler! it will really help!
Old 12-23-2004, 11:00 PM
mattr228's Avatar
I had a problem where the more runs I made during the night the worse my ETs got , I couldnt run consistant times at all with the 4L60E, once I slapped in a B&M tranny cooler it shaped up and finally ran consistant.
Old 12-24-2004, 01:33 AM
thebernsZ28's Avatar
You don't have to have one but I would not drive around without it. Think of it a prevent. maint.
Old 12-24-2004, 01:37 AM
blkZ28spt's Avatar
Highly, highly recommended. Even WITH the tranny cooler you can see high temps if you happen across a horrible driving environment. I got nearly 220* once and I hate to think what would have happened had I not had the cooler.
Old 12-24-2004, 06:48 AM
JEB99TA's Avatar
Thanks for all your comments ... sounds like I'd be crazy not to buy/install one. I was looking at the B&M supercooler, but, with the FTRA I have on my car, I don't think it will fit. Anybody have the FTRA kit with a B&M????
Old 12-24-2004, 10:11 AM
blkZ28spt's Avatar
I only have the SLP CAI, which doesn't take up as much room as the FTRA, but by the looks of it you should be okay. I'm sure you can find somebody who actually has both to be sure but I think it'll be fine.
Old 12-24-2004, 11:36 AM
2001NBMZ28's Avatar
I have FTRA and a B&M 24K on my car - mounted mine "Dope" style:
http://fear.net/~dope/old_camaro/tranny_cooler/
Old 12-24-2004, 02:04 PM
69_YENKO's Avatar
Hey, what ever works. we have the same stall/cooler, what does your trans temp normaly run at?
Old 12-24-2004, 02:23 PM
Twitch's Avatar
Hey, that's pretty cool (no pun intended) .
I've got a B&M on my LT1 A4 and believe me, it's cheap insurance.
Old 12-24-2004, 02:47 PM
2MuchRiceMakesMeSick's Avatar
YES its necessary. It probably wont give you better ETs (unless your tranny switches to hot mode and starts shifting at a lower mph/rpm). Ill put it this way, you can buy one now, or you can buy one with your next tranny.
Old 12-24-2004, 02:56 PM
mattr228's Avatar
sounds exactly what mine was doing at the track after a few passes, i could barely trap 100 mph after 5 passes w/ a catback/lid/suspension A4
that dope install is pretty neat, might have to do that... mines been rattling since I put mine in ... putting those ties through the radiator is not the easiest task while on your back
Old 12-24-2004, 10:35 PM
JEB99TA's Avatar
I appreciate all the feedback. For the cost of a B&M cooler, I'd be nuts not to shell out the cash for it. You've all definitely convinced me without a doubt.
Old 12-24-2004, 10:53 PM
2001NBMZ28's Avatar
I don't have a trans temp guage, but have seen posts of 180 degree average with this setup.
Old 12-24-2004, 11:45 PM
69_YENKO's Avatar
Oh thats cool, mine always runs about 150-160*. I was just curious what you run, since we have the same setup as far as the transmission goes.
Old 12-25-2004, 12:25 AM
SmokingWS6's Avatar
Its cheap insurance! I run cooler with my vig than I did with the stock converter and stock thermostat.
Old 12-26-2004, 07:35 AM
JEB99TA's Avatar
Ordered a B&M 19K GVW. After measuring some space (or lack thereof), I figured 3/4" will be enough and will be about as wide as I can get away with.
Old 12-26-2004, 11:37 AM
SmokingWS6's Avatar
I'd step it up to a 24k cooler, they will fit just as well. I ended up with a 19k because thats why my friend had laying aound unused.
Old 12-26-2004, 02:02 PM
JEB99TA's Avatar
I would go larger, however, I have the FTRA kit installed on my car. It's gonna' be tight maikng it fit, as is. Otherwise, I definitely would've went with the larger capacity one.
Quick Reply: Tranny cooler .. really necessary ???
