Best 4l60e
Old 01-06-2005, 02:38 PM
99SeanWS6's Avatar
Default Best 4l60e
What is the best built 4l60e aftermarket trans out there. I'm thinking of going with the FLP level 4 unless there's a better one out there around the same price. Thanks
Old 01-06-2005, 03:05 PM
maddboost's Avatar
How much power are you planning on running? We offer two built overdrive automatic transmissons for your car, a 4L60E Level 4 and 4L65E Level 5. The 4L60E is recommended for stock displacement motors, mild forced induction setups, generally around the 400 to 550 rwhp range. Our 4L66E Level 5 is what we recommend in anything making more power. We regularly have cars making 650 to 750 rwhp running our Level 5 transmission. We even have one customer whos C5 is making 725 rwhp and has over 150 track passes on it and its shifting as strong as the day we put it in. Give use a call if you have any other trans questions.
Phil
Old 01-06-2005, 03:13 PM
99SeanWS6's Avatar
Right now I am probably running 375ish and plan on in the future making about 450.
Old 01-06-2005, 03:16 PM
maddboost's Avatar
I would definitely recommend our Level 4 transmission then.
Old 01-06-2005, 03:31 PM
99SeanWS6's Avatar
have you had any issuse with it?
Old 01-06-2005, 03:33 PM
maddboost's Avatar
None what so ever as long as the transmission is installed correctly, use only Dexron III, and you dont overheat it at the track you should get years of use of it. We have sold hundreds of Level 4 transmissions all over the US and we even have shipped some to Europe and Australia.
Old 01-06-2005, 06:28 PM
blue2000Z28's Avatar
Well when i get back from Basic, you'll have your self another customer
Old 01-06-2005, 08:56 PM
99SeanWS6's Avatar
do they come with a new torque convert, if not then what torque converter would you recommend? This is my daily driver by the way
Old 01-06-2005, 09:42 PM
Birdman7389's Avatar
I'm very happy with my FLP stage 4......mine is behind a bolt-on LT1.
