?? for anyone with a 3500 stall or higher
Old 01-07-2005, 11:37 AM
Anniversary "Z"'s Avatar
Default ?? for anyone with a 3500 stall or higher
Once you had it installed how important was it to get the car reprogrammed. From information I was told anything over 3400 tells the computer the transmission is slipping. If this is the case how does it drive without a tune?
Old 01-07-2005, 03:29 PM
rufretic's Avatar
Mine was alright for the couple days I had to wait for the tune. I never went hard on it though. I could tell a huge drivability improvement after the tune even though it was just normal driving. I recommend a tune 100%
Old 01-07-2005, 04:49 PM
qwk93ta's Avatar
I have a 93 T/A and I have over stalled mine, the computer put the tranny in limp home mode, Third!! what a pain when it does that when you are in the water box!!!
Old 01-08-2005, 02:57 AM
boosted03cobra's Avatar
you must tune it will drive way better
Old 01-08-2005, 09:09 AM
Kenafin_02TA's Avatar
You'll probably do ok if it's only for a day or two..but I would plan on some tuning at somepoint shortly after the install. I know with mine (a 4200 stall)...I needed to adjust shift points, edit the torque management, and take care of one code (P0757) that would lock me outta first and 4th.
Old 01-08-2005, 11:31 AM
ShadowLightCSU's Avatar
I have an 02 and so far, it feels pretty solid without a tune. I'd have to say, this converter actually drives much more like stock than my Midwest 3400 in my 98.
The only things that seem odd is that it locks up hard enough to feel around ~35 and when it downshifts it isn't bone jarring like the Midwest was. I am assuming that's torque management.
But, it launches hard as hell, I can power sideways entirely through first gear. There is no hesitation to lockup and the only noticeable difference from stock is going through <10 mph in parking lots it takes a little more pedal. If I didn't know autos and didn't drive LS1s, I'd never notice the TC, very streetable. No codes yet.
Old 01-08-2005, 11:45 AM
Red 01SS's Avatar
I have had a 3600 in mine for 8 months or so and have not had any tuning. The car is just fine with the exception of it dying sometimes in reverse. Seems to runs strong as well....no tuning at all and its just a little bolt-on car running 12.2's
Old 01-08-2005, 12:00 PM
WJ SOM SS's Avatar
Get some type of tuning soon as you can. Usually upshifts feel fairly normal, but kick-down shifts are usually all fouled up w/out a tune and a higher-than-stock stall....W/edit, or some other form of custom tuning, it will be a world of improvement. WJ
Old 01-08-2005, 12:38 PM
sstz28's Avatar
get tuned for the stall it makes a difference. i had mine tuned after 2 days
Old 01-08-2005, 12:57 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
6400 rpm stall in my Firebird, just to add some perspecitve
Old 01-08-2005, 02:06 PM
Fouled up downshifts meaning?
Old 01-08-2005, 02:17 PM
BriancWS6's Avatar
I drove my converter for a good bit with no tuning. Only complaint is the torque management was a PITA, and it would sometimes die when I was backing up the slope into the garage and would suddenly let off the pedal. I just lived with it until I got tuned for the cam.
Old 01-08-2005, 02:50 PM
jay_99z's Avatar
Never had any tuning with mine. Drives great, races better......
Ofcourse, I don't know what I'm missing until I get it tuned. So far around 40,000 miles with a 4200 stall. Should be getting HPTuners in the spring.
Old 01-08-2005, 02:51 PM
WJ SOM SS's Avatar
Meaning sometimes will not kick down properly from 3rd to 2nd or 2nd to 1st from certain speeds until around town shiftpoints are edited for stall converter. WJ
Old 01-08-2005, 05:24 PM
JEB99TA's Avatar
Mine did fine before the tune. The car ran well and shifted great. After tuning, it felt better and the tuning made a big difference in the 'feel' of the converter. I had made a LOT of changes since Tim at Macedo tuned my car late last spring. Mucho changes threw my tune off and my car was running pretty rich. After the re-tune, I'm very happy.
Old 01-08-2005, 06:21 PM
sleeperstyle's Avatar
you may have t/m issues (since you ARE putting in a shift kit too, right? you should...).
the only issues i had w/ a 3500 and 2.73's was torque management.
Old 01-08-2005, 10:42 PM
Spdmini's Avatar
8 or 9K miles no tune, no problems.
Old 01-09-2005, 12:36 AM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
I've got around 60,000 miles WITH a 3500 stall, about 118,000 total. Never had any tuning, other than HPP3 to set shift points, rev limiter, etc. Sometimes in the winter I would get a code (PO757? - don't remember) before I started swapping my (aftermarket) trans cooler lines when cooler weather starts.
Old 01-11-2005, 02:00 AM
LS1_PNYTAMR's Avatar
so a tune helps drivability... but will something like a mail order tune from tsp when i get one of there cams do the trick if i ask for them to set it up for my converter as well.. i just need the mial order tune for a few months till i can make the trip "4 hrs" to the dyno... sucks, but i cant make it without a tune, and im pretty sure they can get there own cam close enuff but will they bother with a converter?
Old 01-11-2005, 03:40 AM
Blacker's Avatar
Mail order tune will aid in driveabilty with a higher stall converter. Things that would be adjusted would be:
1. Shift firmness
2. Misfire detection
3. TC Clutch lock and unlock speeds
4. Torque Management Adjustment/Deletion
Tunes after the TC upgrade are not neccessary but, will help with dailiy driving if the stall is real high.
