1999+ 4L80E Truck Transmission
Old 01-19-2005, 12:36 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default 1999+ 4L80E Truck Transmission
I think the 6.0 trucks have a 4L80E option?
If so, it would be the closest to a bolt-in trans.
So here are my questions:
-Is there a 6.0 4L80E truck trans?
-Can you splice on the right connectors from the '60E to make the '80E work or do you have to change the pinouts?
-The '80E requires a different size converter right, and what is the spline size difference, and the spline count?
Old 01-19-2005, 01:51 PM
SSU Moderator
RyanJ's Avatar
Yes! Street car!
I don't know about the pinouts, etc. that would help you and your setup (BS3) but there is a connector-to-connector harness available from Speed Eng. They seem to sell the most parts for the swap for trucks. Have to talked to Mike in Ohio?
Old 01-19-2005, 02:53 PM
LS1Tech Co-Founder
I had a good call with Mike @ Yank, thanks Mike! Sounds like the tables might be different because the solenoids run according to a different algorithm.
Old 01-19-2005, 03:23 PM
SSU Moderator
RyanJ's Avatar
heh? Are you not using BS3 as a stand alone? If so, why not add Meaney's controller?
Old 01-19-2005, 06:16 PM
LS1Tech Co-Founder
I'm not asking for my car, but for a friend of mine.
Old 01-19-2005, 06:45 PM
SnakeOiler's Avatar
This is mainly for a truck conversion, but I think several items can get you where you need to be.
http://speed-eng.com/store/index.php?cPath=23_940_1409
Old 01-19-2005, 06:59 PM
whitt1's Avatar
All 99 and 00 6.0 motors came with 4L80Es,01 and later 1tons and HDs came with 4L80Es,01 and later Denalis and Escalades came with a 4L65E.As far as wiring John at Speartech can furnish the main adaptor plug and speed sensor cables with pins for the PCM.
Old 01-20-2005, 02:04 PM
obZidian's Avatar
speed engineering seems to be on top of this... wiring harness, computer upgrade..etc.
MY question now is, how much power can a FULLY built 4l80 handle and who does this sort of stuff?
Old 01-20-2005, 02:20 PM
Deckhand's Avatar
I think parish ran 10s on a pretty much stock 80e, and a PI verter.
Old 01-20-2005, 04:18 PM
NO-OPTION-2002's Avatar
Right, and thats 10s in a 4500ish pound truck, which is a lot more load/stress than running 10s in a 3400ish pound f-body.
A 4L80E is the direction that I am going to take when my 4L60E dies.
Old 01-20-2005, 04:22 PM
Deckhand's Avatar
definately a worthwhile investment.
Old 01-20-2005, 05:41 PM
SnakeOiler's Avatar
I believe I read somewhere that it was in the neighborhood of 1000lbs.
Old 01-21-2005, 05:58 PM
12 Second Truck Club
one92rs's Avatar
Talking
i run a 1997 4l80e with a bolt on yoke. yes the verters are different. bigger. a speartech harness will be needed. flexplate will be needed and the spacer and bolts. the pcm i am running is from an 02hd truck. then i set in my tuning tables and i was off. i was told that my built 80e can handle 900ftptq.
Old 01-21-2005, 11:18 PM
whitt1's Avatar
Yes,the 4L80E from a 6.0 truck will bolt straight up on a LS1 motor.Talk to Chuck at FLP he's building my new transmission,he claims that I can use a stock 4L60E flexplate with my new Vigilante converter,if that's the case you would'nt need a crank spacer or 4L80E flexplate for the conversion.
Quick Reply: 1999+ 4L80E Truck Transmission
