Car likes to die in reverse after converter
Old 01-19-2005, 01:01 PM
Ryan1985's Avatar
Default Car likes to die in reverse after converter
Does anyone else have this problem. Is happend like 5 times so far just wondering if its normal,
Old 01-19-2005, 01:05 PM
99PTA's Avatar
your throttle body hole need to be drill out 2 sizes bigger... your cars not gettin enough air.
Old 01-19-2005, 01:11 PM
12secSS's Avatar
Actually, it is the mass of the converter that affects the idle speed. The newer converter is lgihter and won't maintain the rpm advantage of the OE heavy converter. Have someone in your area with HPTuners bump up your idle about 50-100 rpms, that will cure the problem.
Old 01-19-2005, 01:56 PM
2001NBMZ28's Avatar
I had the same problem, raising the in gear idle speed cured it.
Old 01-19-2005, 02:52 PM
Ryan1985's Avatar
ok thanks guys..
Old 01-20-2005, 08:20 PM
02 wife's Avatar
After I Had My Vig 2800 Installed I Had The Idle Raised A Couple 100 Rpms. It Cured My Stalling Problem.
