Moroso filtered trans cooler??
Old 02-10-2005, 04:38 PM
Harley-Davidson88's Avatar
Default Moroso filtered trans cooler??
I saw them in summit while searching for a cooler. Has anybody tried one? Any reviews?
Old 02-11-2005, 08:29 AM
Ragtop 99's Avatar
The trans has a filter so I don't see the advantage of a second filter and a filter may reduce flow.
A 19k GVW B&M supercooler handles most situations involving a higher stall. I'd get that and be done with it.
Old 02-11-2005, 10:25 AM
The only reason it really caught my eye was the size and shape would make it easier to find a mounting spot and I am fond of having a filter outside of the trans case (not only is it easier to change the filter, but you can also keep an eye on it to see how your trans is running without dropping the pan). I was just curious if anyone has used one (although I did notice that Jeg's says it is "for track use only")
